1 - 1 of 1 Posts
ยท
ExtremeTerrain.com Sponsoring Vendor
ยท
Feeling like your OE headlights just aren't doing the trick either on asphalt or the trails? Then check out these Raxiom LED Headlights which will give you a better beam along with better brightness.
Designed as a direct plug and play for your factory headlamps these DOT compliant high powered lights are going to ensure whatever comes your way will be totally lit with their 6000k output on both high and low beams.
If you're familiar with CREE then you'll know that they mean business. These LEDs put out roughly 2200-4800 raw lumens (That's pretty bright guys!) Considering how bright they are they only draw a mere 2.0 amps so no need to be concerned if you're powering anything else on board.
These headlights have a sealed black die-cast housings with a corrosion resistant coating. Additionally each light is finished in a durable polycarbonate lens with electronics sealed in epoxy for corrosion and moisture resistance. They're meant to be abused!
Wrangler Fitment: 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015
Item # J103746
Just like any other Raxiom product these headlights come with an industry leading lifetime limited warranty.
Let me know if you have any questions and check out some reviews below!
1 - 1 of 1 Posts
