Sponsoring Vendor
Diode Dynamics is pleased to offer our new USA-made SS3 LED Pods!
Introducing Diode Dynamics new SS3 LED Fog Light Kits for the 2018+ Jeep JL Wrangler! Compatible with both the plastic and steel bumpers, our SS3 Fog Light Kits allow you to mount two of our 3" SS3 LED Pods in your factory fog light location. Our LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
4446864
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered TIR optic in the SS3 collects all of the light from the LED, drastically reducing wasted light and improving total efficiency.
While these outdated optics lose up to 10% of the light output shining through an outer lens, the SS3’s custom-molded TIR optic functions as both the optic and the main lens, dramatically increasing the amount of usable light output.
Functional Patterns: All SS3 LED Pod beam pattern options were designed with optical simulation modeling, to shape the light output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is an SS3 LED Pod for you!
  • Our SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
  • Our SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
  • The Flood optic was engineered to provide uniform, even illumination with a full 60x60 degree spread of light. Unlike typical "flood" lights that are just a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout. It’s the perfect optic for use as a backup light, lighting up tight trails at low speeds, or for loading trailers and setting up worksites.
  • Finally, our Spot optic is an unmodified pattern, shining light directly from the TIR optic. The result is an extremely focused 6-degree beam of light, perfect for directing light far into the distance. With an incredible output of 151,000 candela, the SS3 Sport shines a half-mile away (¼ lux), from a compact 3-inch package!
Not just off road! When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use*.
*Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow: Our SS3 LED Pods are available in your choice of 6000K cool white or 3000K selective yellow. The white is a 6000K color temperature, which is a true white output, without any blue, and is a perfect match for most OEM LED lights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a totally unique look on the road.
Sport or Pro: Stage Series LED Pods are available at two different power levels. Both the Sport and Pro options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power!
Simple Installation:
All SS3 LED Pods feature a custom-molded DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire the SS3 yourself, use an off-the-shelf Deutsch DT sized wire harness, or select an optional Diode Dynamics wire harness. Our Light Duty Dual Output Harness can be used to power up to two SS3 LED Pods. If you are looking to install more than two SS3 pods, we recommend using our Heavy Duty Dual Output Harness along with a Deutsch DT Splitter.
4446865
Proven Reliability: Our SS3 LED Pods have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like OEM components!
If you have any questions, please don't hesitate to post, PM, email [email protected]
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
4446866
