Hey all,Considering building a TJ 4wd for a 0-60 machine..using a 6L GM engine
opinions? does it look like there's enough room for a single turbo underhood ?
which transfer case/front diff is strongest ? I'd probabaly use a 4L80 auto and ford 8.8" rear ?
I'd like a 0-60 monster.
a turbo on the stock 6L has put mustangs in the 8s and 9s....
ideas/advice/opinions are appreciated !
Rich-
Get a LJ for sure if you are seriously considering this. Tj wheelbases are just too short and would be scary under heavy acceleration like that. What size tires do you plan on running? Slicks or normal tires?
Remember jeeps are pretty heavy and it sure wouldn't be pretty if you got sideways at 90mph...
