Hi I'm new to the site and hoping someone may have seen this problem. My 02 TJ with a 2.5L has a hesitatio/buck when I run the A/C. It runs good (as good as a 4 cyl can with 33" tires) with the A/C off. Anyone seen this before? Thanks for any help.
My 6 cylinder would do this from time to time. I changed the plugs and wires, don't know if that was the problem...but it stopped after that!
Sorry
My bad. Should have given more information. I replaced the cam sensor,plugs,wires,cap,rotor. I even changed the compressor because it squealed. I drove with a scan tool hooked up and couldn't see any sensors out of range. I checked the fuel pressure and it even turns up good. Thanks for any help.
