1 - 14 of 14 Posts
I took my cowl hood off and it is all clean. a/c drain is draining properly. I thought maybe a door gasket or something. But I cant see where it is leaking anywhere every thing seems dry on the sides. Water just puddles up in the floor pan.
I have this problem with my soft top, water leaks through passenger side window or above window as I have full doors
any fix to this?
you mean the hinges? andwhat do you mean you pulled the top in? sorry its just that im in Virginia land of the never ending rainfall and humidity and I don't want rust forming on the passenger side
2015 Willys Wheeler W JKU and 1984 CJ
I had the same issue and was certain it was coming in behind the dash. I did the under-cowl cleaning and sealing, and the drain tube extension. No help. Finally replaced the door rubber seal and not a drop ever again! Good luck!
Mostly old school..!
Did you just look in it, or did you take a rod and stick it down through the drain and flush it out with water? There is a rubber boot at the bottom center that needs to be opened up with something, then sprayed with a hose nozzle (if you haven't done it)
thanks ill have to try this, its getting to the point where you can clearly see the water dripping down the window and door panel
Same problem with my hardtop TJ.
Replaced the door rubber seal, it still leaking.
Finally, removed the cowling grill and clear drain hole,
remove foam gasket between the air intake cover and cowling, then
adopt silicone sealant to seal the intake cover.
Job Done !!!
You can do some search on internet for detailed guide.
1 - 14 of 14 Posts
