1 - 9 of 9 Posts
The turn signal isn't working in my '03 wrangler.
I've replaced the turn signal switch, relay and the fuse.
What do I need to do next?
Check your fuses as well on my tj my left blinker was staying on it was due to one of the filaments being burned out and a short to ground I'm not really sure who u go about Checking everything just sounds to me like your not getting power to the relay if its not working because if your bulbs were blown the blinker would still blink but faster letting you know something was goin on . I'm not an electricians just a jeep guy technical I am not but I'm sure there are guys other than my self with tjs that can lead u in the right direction I can't kill my 98 sport however a blue hair almost did yesterday in her 70 model Buick lesabre land yacht :-/ good luck brother of jeep
RETIRED MODERATER
Yes, it sounds to me like a grounding problem!
I also recommend that you re-post this in the TJ Technical section.
Maybe Kjeeper10 will be kind enough to move it for you.
Good Luck.........:thumb:
1 - 9 of 9 Posts
