What color is the Ignition switch Wire on a 04 LJ? I am trying to instal a kill switch. Any suggestions on where to place, or what to connect to are appreciated.
Knows a couple things...
Install the kill switch into the ASD (auto shutdown) relay circuit instead which will kill pretty much everything that is needed to start the engine. The ASD's relay wiring is easy to get to by simply unscrewing the relay enclosure from the fender well.
Jerry,
Thanks for replying...
Is it under the hood (driver/passenger)... How do you instal it in this place?
