Okay, I know there's been threads on this topic before but seriously I'm getting so annoyed with the size of the leak coming from the 2 doors. It seems to be getting worse and worse!!!! Has anyone found any fix or anything that is minimizing the leak????
Here's a few pictures of the water... This is about the 5th time in the last 2 days that I've cleaned it up. Had to rip the carpet out so that it might dry.
I noticed my center bow is favoring the left side, don't know if its possible-it could be shifted over some. Took a pic of the latch
Going to disco and see if I can center it better.
My leak is on the right so makes sense if the center bow is not centered-one side is going to be open allowing water in.
After work I'm gonna bring her through the
wash :)
I Need A Cigarette
2 things...
1. Simple Green the door seals; apply to rag wipe/rub into seal, wipe off with damp rag after 30sec. or so...
2. check the corner seals and make sure they aren't pinched or folded under the top...
