I changed my coolant temp sensor, turn it on and drove around the block everything worked great. When I got home I tried plugging in my scanner and the car immediately shut off. All the lights are working as well as the power locks. When i try to turn it over the radio shuts off for a second, there is engaging of the starter. Can anyone help me get to the bottom of this?
If I read this right, you plugged the scanner in with the Jeep running? Personally, I always plug into OBD ports with the power off.
Try taking the negative cable off of the battery for 10 mins.. then reconnect and see if it will start
