2009 Unlimited Sahara w about 60,000 miles - Auto tranny. It has now happened 3 times. The vehicle becomes "stuck in neutral" after shifting reverse to forward or vice versa. I can crawl underneath and manually push the shifter into gear and it will drive but the connection from the cab to the tranny, something is worn and coming loose. They tell me if it happens again, I need a new "Mopar" $600 shifter kit installed.
I have always been in clean clothes when it happened and had to have a dealer fix it for me on the road quick so I don't know what they are fixing. 2nd, I'm guessing there is likely a better aftermarket solution to fix this. Please advise and thanks in advance.
Discussion Starter #2
I looked at one of the repair orders... says the shift cable retainer is worn. Is there an aftermarket kit to fix this?
Try bushingfix.com. I used their piece for the transmission end of the cable on my '09. Doing well so far.
