Hey everybody I have a 2009 Jeep Wrangler X and it's been running great up until today. Went to go somewhere, started it and the ABS light, emergency brake light, ESP BAS light and check engine light came on. Emergency brake is off, and it drives still, only thing is my odometer won't change and neither will the speedometer. Stays at current milage and speed reads 0mph.
Also, how old is the battery? Check the voltage before you try to crank it. Should be better than 12.5VDC. Then after you start it, should be +/- 14.5VDC.
