I ordered those 1 3/4" coil spring spacers from Pro Comp for my front coils, they came in today. I am going to put them in when i get home from work tonight, anyone know if i simply have to disconnect the sway bar and unbolt my shocks, or does the trac-bar have to come unbolted too? I'll try to post pics tomorrow of the install.
Retired Moderator
Hawg, you only need to undo your sway bar and un bolt your shocks on the bottom. Then if you have a hi lift or something then it will only take you like 15 minutes a side.
