I know. I know this has probably been discussed (over discussed) on here many times. But I'm new here and and contemplating one. I have a 95YJ with a 1" boomerang shackle lift that gives me just enough claerance for my 31X 10.5 BG's. Thinking of trying to sqeak another inch for a little more clearance. I've been told it's fairly simple, will not require a change in shocks, other than the radiator shroud having to be lowered that the wires,brake lines, transfer case should be fine. Also, will I notice a difference in the engine compartment? Thoughts? Pros and cons?
nope all is good. a 1-1.25in bl and 1in mml will be just fine for what your thinking.. so on that note.. whats a "BG"?
XJ-Yeah I mis-typed. Should have typed BFG's.
XJ- Also. I'm trying to avoid The Motor mount lift. Is it neccesary? If i don't use it other than lowering the shroud what's the negitives.
