1 - 20 of 51 Posts
I finally found a vendor that has a working winch plate and bumper additions for the 10th Annv! So far so good, the parts are really well made and I love the way that everything fit together. The hoop on this is super stiff and when rocking the jeep by pushing around on the hoop it moves the whole jeep! :punk:
Here are some pics I snapped of it all together! You guys are all right, modding these bad boys is like a drug! :thumb:
Now onto some pics!
Where did you get info for ordering? I don't see the 10A plate listed on their website.
That's a great looking set-up.
Not judging it at all or saying its a bad thing, but that steak going into the frame rail pocket looks a little small. I know the one on my warn mount took up the whole pocket. I'm not saying it is a bad design or anything, just something I noticed. Looks great tho!
Discussion Starter #10
I just called the number on the website and they gave me all the ordering info.
That is the mounting bracket to reinforce the hoop. I am going through my iphone for the picture I took of the winch on the plate. I will upload that in a minute here. :thumb:
Discussion Starter #11
Here are some shots of the winch plate itself (ignore the black bolts in the bumper bolt spots, I just put those there to hold it up).
Discussion Starter #15
What process is used to center the fairlead ? I can't believe Jeep would actually put the fairlead opening off-center.
We used a hole saw to cut a larger opening to center out the fairlead. And to answer your other question Jeep does have the fairlead off center.
I sent Maximus an e-mail on Tuesday and they proptly responded. Here's what they said:
Hi Caveman,
I'm following up on your inquiry about our 10th Anniversary Rubicon
Bumper Module (Bar/Hoop, Aux. Light Brackets, Winch Mount, EX10000
Maximus Winch).
Here are the key product features:
1- 2.5 Inch steel tubing hoop/bar with welded attachment flange and
reinforcement/stiffening brace brackets.
2- Auxiliary light brackets with 1/2 Inch light fixture holes.
3- Winch Mount: 1/4 Inch steel plate, centered and off-set winch
attachment points provided, compatible with multiple winch bodies and
brands. The plate mounts to chassis frame with two 12mm grade 8
bolts in the back and two existing 12mm factory bolts in the front.
4- 5mm steel fairlead centering plate for centered winch position (optional)
5- EX10000 Maximus winch with synthetic cable. The winch mounts in
centered position and does not require vacuum pump relocation.
6- Vacuum Pump Relocation Bracket (optional for off-set winch position
and other winch brands). The bracket bolts on to the winch plate with
two 6mm bolts.
7- All components are painted in textured black powder coated.
8- Bolt on installation utilizing existing factory attachment points
(no drilling or cutting required).
Introductory Prices:
1- Hoop & Auxiliary Light Brackets: $299.99
2- Winch Mount (without fairlead centering plate): $129.99
3- Winch Mount & Fairlead Centering Plate: $159.99
4- Fairlead Centering Plate (optional for centered winch position): $34.99
5- EX10000 Maximus Winch with Synthetic cable & Hawse Fairlead: $794.99
6- Complete Package with EX10000 Maximus winch: $1254.99
7- Vacuum Pump Relocation Bracket (optional for other winch brands): $29.99
The product will be in stock some time next week. At this point we are
only taking order list/queue for those who want to get the first
production lot.
Regards,
Joe
Maximus-3 Sales
MAXIMUS-3
2295 N. Opdyke Rd, Suite E
Auburn Hills, MI 48326
P: (248)-821-6654
E: [email protected]
I wonder if he plans to offer the light brackets separately? I like the mount and the light tabs, but don't see the need for the hoop.
Discussion Starter #18
Give them a call at 1-248 821 6654 or email them at [email protected], they got back to me promptly back when I first called them looking to see if they were making parts for the JKUR10A. :punk:
I'm picking up my complete kit this Saturday. It's my understanding that you can buy all the parts individualy.
1 - 20 of 51 Posts
