1 - 20 of 81 Posts
Land vehicle Vehicle Car Tire Jeep
This current build theme is “Off Road Expedition”. It is centered around the 2013 “Rock Lobster” Jeep Wrangler Unlimited. This build is being accomplished for a Photo shoot for the cover of 4WD.coms Catalog. The photo shoot will take place on Saturday April 13th.
Prior to beginning this build on April 2nd the following had already been completed on the build:
ProComp 7032 rims
315/75/16 Good Year Dura Trac Tires
Front Bumper MBRB Off Camber Fabrications stubby bumper with D-ring mounts and Bull Bar
Rear Smitybuilt XRC bumper and Tire Carrier
Factory flat fender trim
For the build project and Photo Shoot we have 11 days to complete the installation of the following items:
1. Garvin JK Wrangler Overhead Expedition Rack with Wind Deflector and Expedition Rack Ladder
2. Smitybilt Rock Crawler Side Armor
3. Truck Lite LED’s
4. Warn Zeon 10,000lb winch with Synthetic cable
5. Factor 5 Pro-link winch end
6. Rugged Ridge Modular XHD Snorkel Kit
7. 50” rigid LED Light bar to Garvin rack
8. 10” rigid LED Light bar to MBRB bumper
9. Dually D2 surface mount diffused rigid Light mounted into the rear tail lights.
10. 4 Rigid SRM’s (2 on each side) mounted to the Garvin rack.
11. 15lb Power Tank on custom fabricated mount.
12. Custom tool mounts for Highlift Jack, Shovel, and Axe.
13. SPod to control the lighting package
14. Metal Cloak JK Overland Fenders (Front and Rear)
15. Metal Cloak 3.5” Dual-Rate lift, ARB Edition
I am still waiting for the last 3 items on the list so I am taking this opportunity to post some build pictures and talk about some of the fabrication that was required to make some of the parts fit where desired.
In for the fab and payoff. Expect to see some interesting things!
Technology Electronic device Tool
OK lets start with the Warn Zeon winch … first this winch is bigger then most other winches and the Off Camber bumper is designed to mount the winch in the bumper. I removed the cable to make it easier to move around, see and work on.
Automotive exterior Auto part Bumper Vehicle Car
As with most bumpers the vacuum pump is in the way! I had already cut it off the frame and remounted it to the bumper, however with the size of the winch ends it hit the vacuum pump again so I had to weld up a new mount farther back and lower down behind the fog lights
Auto part Vehicle Car Fuel line Engine
Pump moved
Electronics Technology Electronic device Auto part
Now with that out of the way I was able to set the winch into the bumper only to find that it was resting on the in bumper fog lights. I cut and machined 2 - ½” aluminum spacers for the winch to clear the fog lights.
Automotive exterior Bumper Vehicle Car Vehicle door
With the spacers in the winch fit nice. You can see the spacer and the mount in this picture looking thru the front opening.
It would not bolt to the most forward mounting holes because the winch was hitting on the “D-ring Mount” bolts so I had to move it back 1 hole. As seen in the underside picture.
Bumper Automotive exterior Vehicle Auto part Car
Fairlead mounted
Bumper Auto part Automotive exterior
This is the end piece that holds the rope in
Vehicle Car Automotive exterior Bumper Automotive design
Another view
Automotive exterior Bumper Auto part Vehicle Tire
And the rope wound
Automotive exterior Auto part Bumper Vehicle Grille
Now because I hand to move the winch back 1 hole I could not get the 3 center clips of the front cowl into the frame so I cut the clips off.
Land vehicle Vehicle Car Automotive exterior Bumper
It is a tight fit and the winch pushes the lower cowl in about ½ inch but it looks fine
Motor vehicle Vehicle Automotive exterior Red Bumper
Here is a side view of the push in
Top view of the same
Land vehicle Tire Vehicle Car Jeep
And all completed and wrapped up…….
So the end result is YES it can be done on this bumper how ever unless you are good at fabricating I would not chose this combo.
Wood Hardwood Table Lumber Flooring
Next to arrive was the Garvin Rack. 3 of the 4 boxes are the Rack. Let me say that it to a considerable amount of time to unpack the boxes. They do a fantastic job of packaging and protecting their products for shipping
Auto part
All of the components and hardware are individually packed and labeled for each step. It made assembly easy to follow.
Automotive exterior Bumper Auto part Plastic bag Plastic
This is the step pack
Iron Metal Automotive exterior Steel Floor
Sorry for the poor quality photo but this the basket assembled
Land vehicle Vehicle Automotive tire Tire Bumper
To install the rear mounts for the rack, you need to remove both tail lights and the license plate holder.
Automotive exterior Fender Vehicle Bumper Car
Next is to tape and measure 3-4 times before drilling
Automotive exterior Motor vehicle Bumper Vehicle Fender
Then drill
Automotive exterior Vehicle Bumper Automotive tire Tire
Then assemble the mounting hardware and repeat for the other side
Vehicle Automotive tire Automotive exterior Tire Car
After the rack was full attached, the ladder assembly was attached
Land vehicle Vehicle Car Automotive tire Tire
I then installed the Smittybilt side rails and this portion is complete.
Land vehicle Vehicle Tire Car Jeep
The rack is AMAZINGLY strong!!! When you grab the rack and shake it, it does not budge and the whole jeep rocks from sided.
Land vehicle Vehicle Car Jeep Tire
Front
Land vehicle Tire Automotive tire Vehicle Automotive exterior
Rear
Land vehicle Vehicle Car Automotive tire Jeep
Next is the Rugged Ridge Modular XHD Snorkel Kit! This was almost an all day project with all the steps required to install it. The directions are clear and come with the template for the cut out in the fender. Here is the picture with the fender removed
Vehicle Car Automotive exterior Transport Mode of transport
And here is the snorkel done. Sorry I got so tied up with the instructions and installation I for got to take the step by step install pics.
Land vehicle Vehicle Tire Car Automotive tire
Also the Factor 55 Prolink is now installed on the winch end
Brickwork Brick Wall Room Bricklayer
Next the Rigid Industries lighting showed up!!!!! Its so pretty :)
First the 10” on the bull bar, I ground off the factory tabs on the bull bar and moved them apart to match the Rigid mounting bracket.
Land vehicle Vehicle Car Motor vehicle Jeep
Next was the placement of the 50” light bar. This rack does not have mounts for a light bar but the bends on each side of the uprights will match up at the right width in order to mount it.
Vehicle Auto part Car Automotive exterior Bumper
Once measured 5 times then I drilled out the mount location
Land vehicle Vehicle Car Motor vehicle Off-road vehicle
It is at a great height but I did have to shorten the snorkel about 2” so it was not blocking the light
Land vehicle Vehicle Car Jeep Automotive tire
Here is with 3 covers
Here is with all the red lenses covers on it
Land vehicle Vehicle Tire Automotive tire Automotive exterior
Next was to remove the factory rear lights so that I could cut and mount the flush mount Diffused D2’s.
Light Red Automotive lighting Electronics Electrical wiring
Lights mounted, the complete step by step details are on page 5 of my other build http://www.wranglerforum.com/f33/matchbox-edition-jku-dozer-build-160398.html
Tail lights reinstalled
Wire Cable Electronic device Technology Electronics accessory
For the SRM’s I cut the factory plugs off and wired them so that there would be 2 plugs at the front of the rack for left and right side lights. The rack tilts back to remove the top. In this way you just unclip the 2 concetors and the rack will tilt back.
Auto part
Here is a SRM rewired and loomed
Automotive exterior Bumper Vehicle Roof rack Tire
The SRM mounts perfect on the rack without drilling and sets nicely between the rails for protection
Land vehicle Vehicle Car Automotive exterior Off-road vehicle
They provide a nice amount of light
Box Auto part Packaging and labeling
The power tank I wanted to mount on the outside of the jeep attached to the rear of the rack opposite of the ladder.
Vehicle Automotive exterior Bumper Car Auto part
Here is the lower mount set for sizing
Vehicle Automotive exterior Automotive tire Tire Car
Tank in to check clearance before fully welding it up
Fully welded and painted, matches the other side great!
Vehicle Tire Automotive tire Automotive exterior Car
Tank bracket fully mounted
Land vehicle Tire Vehicle Automotive tire Automotive exterior
And tank in the bracket
Land vehicle Vehicle Tire Automotive tire Car
It came out great and has nice sementry with the ladder
Automotive exterior Vehicle Transport Asphalt Mode of transport
Here is looking back at it down the side. It has a nice low profile
Land vehicle Vehicle Automotive tire Tire Automotive exterior
Tools mounted, shovel and flat head axe
Automotive exterior Vehicle Car Roof rack Automotive carrying rack
Highlife jack mounted
Vehicle Car
Front wind deflector mounted and adjusted on the Garvin rack.
SPOD, Metal Cloak lift and fenders will be in tomorrow! So final completion will be Friday (maybe an all nighter but Friday) those pictures and some preview shots of the shoot I will try to upload this weekend for everyone
Very Nice Work!
Getting numb at dentist now. They're are giving me pain meds and said no driving once I start em. So I can't come and play with wrenches :(
Discussion Starter · #20 ·
Metal cloak fenders going on
1 - 20 of 81 Posts
