I have the quidratec 11500 pound winch with the wire cable. Can this wire rope be replaced with synthetic rope at home? Anything I would have to do to switch it over?
Sponsoring Vendor
Yes, you are able to switch that wire line over to a synthetic line on that Quadratec winch. You can use this line here:
https://www.quadratec.com/products/92123_20X6_PG.htm
Then you would also just need a Hawse fair lead with this instead of the roller fair lead that you had for the wire cable.
Here is a link to the Hawse fair lead for the Quadratec winches:
https://www.quadratec.com/products/92123_2010_14.htm
The bolt that holds the line to the winch is here also:
https://www.quadratec.com/products/92123_2001.htm
This all you would need to switch that over to the synthetic line.
If you have any other questions just let us know!
Hailey
