I've searched & hope I didn't find the answer, I really don't want to remove 1/2 the dash just for this silly 12v plug.. I want to remove just the panel with the 12v plug, switches & hvac controls. I want to remove the dummy plug on the right side & install a factory 12v plug just like the one on the left side of panel. I have a sport(WW) so its not using both spaces like some models do. Also, is there a factory power plug back there that's not being used on the model that I can use to plug into?
Rick
I don't know if just that panel can be removed or not but pulling the rest to get to it is very easy to do anyway. Not sure if there is factory wiring there or not but it's quite possible. If not you could pull power from the other outlet and put a slightly larger fuse in. If you're going to be drawing a lot of amps then you should wire it properly.
