1 - 11 of 11 Posts
I'm installing a set of led headlights this weekend on my 04 TJ. The lights have the option and wire to either incorporate a turn signal or daytime running light. I'd like to do the drl option so they will turn on when the vehicle is running without having to turn on the parking lights. Does anyone know of a power source in either the turn signal harness or side maker light harness that would do this and if so what color is the wire? Thanks in advance
First don't care for DLR next no wire in light harness only has power when engine is running as you can turn on lights with engine off and only turn signals require key on or acce but the also require turn signal be activated so a no go there
Many places to get power only when key on but not designed to power lights so only use them to close relay to supply direct fuse protected battery power to your day time lights
Possible source for key controlled relay control includes the injectors or coil power as they are constant on when and only when key is on
The actual injector pulse and coil spark control is via ground side control
But lights that you cannot turn off are a bad idea and tend to piss of guards at military and other guarded installations
Sweet deal simple really. I want to do this to my actual head lights and add a switch to toggle in on an off as needed. It is the same thing really but I like having my lights on anytime I have the car on and not have to worry about leaving them on unintentionally.
Biglen718, I've got an '02 Sport and have been researching LED headlights. Have a few questions: (1) how do you like the LED headlights you installed? (2) did you have to install the anti-flicker harness? (3) have you had any problems with the DRL's connected to the switched power outlet? Thanks for any feedback you can provide.
First post from me to this forum. There's a ton of great information here!
1 - 11 of 11 Posts
