Hi All...I'm posting this for my brother who wants to install led signal lights. He's trying to find the signal flasher/module but can't. He's taken apart the steering column but no luck there. He believes that by replacing the flasher unit he can run the LEDs w/o a resistor at each light. Your thoughts?
What nwbronco said above. There is no flasher unit. New vehicles use the main electronics (computer) to control these functions.
You used to be able to do this on the TJ's, the flasher was located on the top of the steering column under the plastic cover. The JK doesn't use one like that so it's not possible.
