Hi all, I have a 2015 Sahara with a manual transmission. Back in July I suffered the broken shifter and had the bushing replaced at my local dealer. Now every so often when I'm Taking off in first gear it will pop out of gear with a Big Bang that scares the shit out of me. It only does it in first gear, It never did this before I had the bushing fixed, and it started a few months after having it repaired. Any ideas would be greatly appreciated. Thanks
The inner shift boot might not have been reseated in its hole when they did the repair. Underneath the nice looking black rubber shift boot, there is another boot/isolator attached to the tub. If that's not in correctly, it will cause the trans to pop out of gear.
I think you can see the inner shift boot from under the jeep, if I remember correctly.
