I've been having a heck of a time with my headlights, specifically the passenger side
I replaced the stock headlights about a year ago with a cheapish amazon set of LEDs
worked great at first, and then bit by bit the headlight would just not fire up
pulling the headlight and wiggling connectors seemed to fix it for a time, but inevitably it would crap out
I felt like the issue was the cheap anti-flicker harness, so replaced that, and again, headlights were good for several months, and then boom, headlight not working again
pulling it apart again, wiggle, and lights come back on
try just a straight h13-h4 conversion (no anti-flicker) and same deal
seems like it's a mechanical/physical connection, and I'm really starting to feel it's in the OEM connector. if you hold the wires just right, the headlight works fine
I've tried zip ties, tape, bunch of combinations, but I'm having a heck of a time keeping a solid connection. what else can I do ?
I guess i could attempt to put on a new oem connector?
Clean up the contacts, put some dielectric grease into the socket. Re-connect, test, and use a wire tie to cinch the connection together tightly (and keep it that way).
2016 Wrangler JKU sport.
Perhaps it's some corroson on either or both (male/female) on the connection pins? I'd trying cleaning both by scraping them with a small exacto blade, sand paper or anything that can get them clean. Then spray them with a good contact cleaner. Worth a try as it costs nothing to do but a little time.
Dielectric grease, or tune-up grease, is a silicone-based grease that repels moisture and protects electrical connections against corrosion. ... The grease does not conduct electricity, so it shouldn't be applied directly to the mating surfaces (pins and sockets) of an electrical connection.
that's pretty much what I did. I used no-ox as the "grease" as that's what we use for battery maintenace.
I had previously had it all zip-tied up, but this time around I ended up slightly bending the pins on the h13 side so that they HOPEFULLY make better contact inside the OEM connector.
re-zip-tied the whole thing, so hopefully stays good for awhile now
