if im going for 5 inches of suspension lift will I need a longer drive shaft or need to address the pinion angles I have the pitman arm drop and t case drop but didn't know about the shafts and angle
First, what size tires do you want to run, and what will you be doing with your Jeep?
That much lift = larger tires (I'm guessing) = more stress on your axles = axle upgrades or swaps = gear changes = SYE and new driveshaft = etc etc etc
Yes, you will... and brake lines too.
(Most lift kits address this and include needed parts - unless you are custom building it.)
If you want 5" or better, why not go SPOA? Lots more flex and clearance!
