Up for sale is my 1992 Jeep Wrangler with a custom 5.3/4l60e swap from a 2002 Yukon. It has no rust whatsoever and is very clean overall. It does have some scratches and a few dings but overall great shape for a jeep. I'm gonna try and list everything i've done to it but I may miss a few things and add them as I remember.
Engine/Drivetrain
5.3 l59 Drive by wire (Flex fuel engine so bigger injectors)
4l60e
S10 np231c transfer case mated to a Jeep np231j to retain stock driveshafts.
Ls3 exhaust manifolds
2.5 inch dual exhaust into 3 inch single flowmaster
New oem waterpump
New oem crank seal
New oem rear main seal
New oem oil pan gasket
New oem intake manifold gasket
New oem valve cover gasket
New oem fixed orifice pcv valve
New starter
New Walbro 255 fuel pump
New B&M shifter
New corvette fuel filter/reguator
New -6 ss braided fuel line front to back
Custom intake
New aluminum dual core v8 swap radiator
Taurus fan wired to come on with pcm
All stock gauges wired up and working
Functioning obd2 port
Transmission pan gasket and filter just changed
New ss braided transmission cooler lines and black anodized an fittings
Custom motor/trans mounts
Suspension/Tires
Richmond Lock-Rite front locker
New lube locker front differential seal
New lube locker rear differential seal
New Rough country 4.5 inch lift
New Rough country 2 inch body lift
New Rough country ss extended brake lines
New Rough country Sway bar disconnects
New Rough country Steering stabilizer
New Rough country nx 2.0 struts
New Posi-Lock axle disconnect
Very good condition Interco TSL Thornbirds 35x12.50/15
Crager soft 8 wheels
New front brake calipers and pads
New rear brake shoes and hardware
Body
New windshield and rubber
New windshield frame seal
Custom built tube fenders
Custom built rocker guards
Custom built rear tire carrier/bumper
New stinger front bumper
New 12,500 lb winch
New brake switch
Black soft top and upper doors (not installed but in good shape will show and older pic fro reference)
bikini top and tonneu cover
Recessed round led tail lights
New headlight housings
Pioneer cd player with usb
New sony speakers
Bestop trunk
Hi-lift jack mounted to hood
Led fog lights
20mm ammo can center console
Led interior and under dash lights
Price is 15k obo But id really like to trade for something else plus cash. Im interested in all sorts of stuff so shoot me an offer through pm or you can text me anytime at 478 320 5614
