1 - 20 of 43 Posts
New guy here. Any help is appreciated. I'm looking to buy my first Jeep and would like some advice on this one that I'm checking out. See the listing below. Will try to upload pics but it's a beaut.
My concern is the gear ratio for 35" tires. I've been reading the forum and have not seen a lot of 3.73 with 35's.
Also, the current owner has stated that there is some occasional wobble. I need to drill into this more. Been reading up on death wobble. I asked the seller if he has ever had to pull over to get it to stop and he said no.
Questions before I pull the trigger:
  1. Is this the right gear ratio for 35's?
  2. If I go down to 33's, will I need to make any adjustments?
Any other questions I should be thinking about? I won't be doing any crazy off-roading, maybe some trails but no rock crawling. 80% street driving.
1993 YJ - $10.5k
Rebuilt engine/transmission, odometer reads 193K miles, but at roughly 100K miles, the engine and transmission were totally rebuilt. So it really has about 93K miles. However, the rest of the jeep & components are much newer.
Ford 8.8 Rear end with a Detroit locker 3.73 Gears front and rear
Tera Flex 4 to 1 transfer case
Rubicon Express 4” lift shocks and brake lines
BF Goodrich (baja champion) 35 X 12.50 tire, less than 5K miles on them, like new
Curie High steering
1” Body and motor lift
Smitty Built front and rear fenders
Smitty Built rear bumper and tire carrier
Smitty Built XRC 9500 WINCH
Tow hooks and tow rings/package
Way too much $$$ I’d say PASS
Reactions: gat
4.88 is about right for 35's with a 4.0, if it's a 2.5 you will need much lower gearing than 4.88.
$5000 overpriced.
You didn't mention engine and trans
3.73 would be good for the following
4.0 5 speed w up to 28" tires
4.0 automatic w uo to 33" tires
2.5 automatic with stock tires
2.5 5 speed with smaller than stock tires.
Retired Moderator
:welcome: to the Forum..:wavey:
Reactions: cmcgillis14
Welcome to the Forum cmcgillis14,
That's a lot of dough for not a lot of Jeep. If it's absolutely spotless with no rust, good paint, pristine interior, full doors & hardtop, six cylinder engine, standard transmission, sanitary modifications and drives out perfectly (seller states it doesn't) it might be worth that much to someone. Not to me. Even if the Jeep has all the above and the seller agrees to re-gear it and install a SYE, I'd keep looking.
Smittybilt parts are entry level parts.
I think 4:88 gears will be best for 35s with 4:56 coming in close behind. 3:73s are too tall for 35s. I'm running 31s and am going with 4:10s.
With a 4" lift, the Jeep should have a Slip Yoke Eliminator (SYE).
You state it has a 1" motor mount lift. Look for spacers between the frame and the central skid plate (crossmember).
Any rust anywhere on the frame or tub would knock $4K-$5K off the price. A speck or two of very minor surface rust isn't an issue, but any scaly rust is a problem.
If the frame has been undercoated or bedlined, for me, that would be a stone cold deal breaker. I'd walk.
Good Luck, L.M.
Like the guys said that pretty pricey. If it has 3.73's it came with a 4.0, cause I cant imagine the PO gearing it that way with 35's and IMO that would not be fun. 100K on a 4.0 is nothing yet it needed a rebuild, why? The AX15 5 speed came behind the 4.0 and it needed a rebuild too? why, been beat on to much? or is it an auto which is understandable if used hard. An 80% street use rig with a Detroit out back? Don't think you'll like that one. I think you're overwhelmed with its coolness...do yourself a grandiose favor and keep looking or get him down to somewhere around $7K if you must have it.
Currie high steer?
I'm going to have to agree with everyone else, and I feel Luckymac hit it right on the head. Even if it were perfect, I don't think $10.5k would be justified.
However, I'm interested in what the "Curie high steering" is. If you decide to test drive or take a look, I'd love to see what seller is posting about. If anyone else knows, please ping in.
Reactions: SoCalC101CJYJTJ
Discussion Starter · #13 ·
It's a 4.0, 5-speed.
I've been wondering the same thing. Why the rebuild?
If I went down to 33's, would the 3.73 ratio work?
According to the ad, the previous owner did everything to this Jeep, including the engine and tranny rebuild. Unless the seller has authentic receipts for those rebuilds, they didn't happen.
Also, the seller calls this a V6 in several places, including the title. Obviously it's not a V6.
This smells like a flip to me. The seller doesn't know much about this Jeep, got some kind of good deal on it, and is trying to make a quick buck.
I wouldent run 3.73 and 35's on a warmed over V8 but that' s just me. Any brake upgrades? 35's weigh a bit as well. You can always go take a test drive and get an idea of how that combo works. I can say this, my current YJ has a 4 cyl and 4.10's and 31's. I like to put around looking for elk or deer, its really rocky here and 90% of the time dont need 4wd. I frequently have to use 4wd just to get a lower ratio and not bog down. Id love to have 4.88's or a way lower first in the thing but that's not gonna happen anytime soon. Go for a drive in it, putt it slow, hit the freeway and try out 5th gear and see how it feels, test drives are free. Keep in mind regardless of what the owner wants you NEVER get your money back after all those mods and $10K is a lot of cash. Its got a lot of mods he apparently knows little about which makes it all the more iffy, so he needs to be patient, up front and willing to work with you.
I can say this however. I used to live in Ca and the bay area has lots of money. Some folks just like to spend big bucks on toys and they never really use them for what their intended. I've bought a few Harley's from guys up that way who dumped thousands++ into the engines and then got tired of that "toy" and moved on to the next money pit. Bottom line is its still a YJ with leaf springs. It use to piss me off watching these guys with TJ's and high zoot long arm suspension hitting bumps or dips and it looked like a Cadillac going over them. The body not hardly moving while the suspension did all the work.
Here's a couple thoughts in addition to what wristwister points out.
No pics of the engine.
Seller doesn't state that Jeep passes California emissions. With no current emissions certificate this could be a budget buster.
If you went down to 31s the 3:73 ratio might be OK. For 31s 4:10 ratio is best.
If the seller wants to make that Jeep into a $7500.00 vehicle, he needs to re-gear it to a ratio that's compatible with the 35" tires and provide a current certificate of passing California emissions. He also needs to have a Slip Yoke Eliminator and upgraded brakes installed.
At $7500.00 I could live with only the soft top if the above issues were resolved.
I'd want to drive it on neighborhood streets, on the freeway and out on some 3-4 rated trails.
Before I even drove it I'd want to see a clean title and I'd check the VIN on the title and compare it to the VIN on the vehicle.
Personally I think OP is ill advised to consider this particular vehicle at asking price. It's unlikely the seller will agree to do the necessary mods even at the asking price. To require the necessary mods and offer a fair price ($7500.00) would be a waste of time.
I strongly suggest that OP looks for a closer to stock Wrangler at a significantly lesser price and modify it to suit his needs. I expect that he'll come in less than $10,500.00.
Good Luck, L.M.
Reactions: Got it at last
$5000 overpriced.
4.0 automatic w up to 33" tires
I already answered this once....
Doesn't matter anyhow since it's priced at double what it's worth...
Good Luck, L.M.
Yep.
Yep.
I say find a bone stock fuel injected 6 cyl with good bones and spend the extra $ the way you want-come here for advice, it’s free
Yep.
Your looking at this one. Overpriced for sure! It’s been on CL for sometime now.
https://sfbay.craigslist.org/sby/cto/d/san-jose-jeep-wrangler-v6-40-pristine/7022713403.html
Yep.
Yep!
Good Luck, L.M.
And guess what, Yep!
It certainly does feel like a flip, and why would that thing have all that work, and .73’s still in it? Just doesn’t make sense.
Yep.
1 - 20 of 43 Posts
