Have a 95 Jeep in the garage that needs a horn...looking under the hood...there are no horns (fiberglass tilt front clip) and and I don't see any loose wiring.
Easy enough to run a wire from the horn relay but...
Would like to know where the original horn wiring ends and starts under the hood, color would help also.
Thanks
drivers side fender
Your '95 wiring should look more like what agalloch07 has in his pic than what I have in my pic of my '87.
What looks like a grey wire is the original wire to a single horn. I added the white wire when I added a second horn.
The horn didn't work when I got my Jeep, so I bought a pair of horns (one Hi note and one Lo note).
The relays are for the headlight wires that belong to a homemade headlight wire harness to provide greater voltage to the H4 headlights without taxing an already problematic stock headlight switch.
Do you have access to a Factory service Manual? A FSM will have the necessary schematics to discover what color wire is supposed to run from the relay to the horn.
Good Luck, L.M.
