  • Hey everyone! Enter your ride HERE to be a part of MAY's Ride of the Month Challenge!
1 - 17 of 17 Posts
Greetings from a small mediterranean country - Montenegro.
I have 1995. Wrangler with 4.0 engine and 32rh auto transmission. I have it since 2012. After going thru hassle with all sorts of issues, shops etc. I have finally decided to do a complete rebuild on my own. Jeep was not a rust bucket, nor the engine was that bad (except it had slight piston slap when cold), so it wasn't that much effort as it could have been. I took me near 7 months to finish everything by myself, except body paint job ( which was done at the shop)
First I started tearing down everything
Looks good so far. Let’s see more
Here are a couple of photos of frame restoration. I removed most of the rust with wire wheel brush.. For some deep rust which I couldn't completely treat with wheel brush, I used rust converter.
Prepared for painting, dark blue/black color over frame is rust converter:
After coating with 2k washprimer:
Next day I applied one coat of 2k polyurethane paint - semi gloss
This is frame after paint job:
Next - front and rear leaf springs and differentials - coated with epoxy primer and later with polyurethane paint just like frame. Old paint and rust were completely stripped off from everything, it took me a lot of time to finish that. I could have saved a lot of time by sandblasting everything instead of using a wire brush. However, the sandblasting shop was far away from me and also they gave me an abnormal quote for undercarriage
That's a work of beauty.
Please keep posting. I'd love to see the final product.
Good luck, L.M.
Thank you guys!
Here are some more pictures:
Leaf springs, frame and axles ready:
Got engine from machine shop - 0.01" on both crankshaft and pistons
Everything except transmission and engine mounts is polyurethane. These are from energy suspensions:
Frame is ready! 2.5" inch suspension lift with Skyjackers h7000. To be honest, this is harshest ride I've ever experienced
Engine block is back onto the frame.
The 2.5" lift shouldn't cause that harsh of a ride. A common issue that leads to a harsh ride is over tightening the shackle bolts. The torque value in the typical instructions is way too tight and does not allow the suspension to move as it should. I believe the general consensus is to torque to 45 ft/lbs. I'm not sure what that relates to your metric values. :)
Discussion Starter · #11 ·
Thank you, this was (combined with track bar removal) first thing I had tried, however no difference at all :)
Here are some more photos of piston and head gasket installation, transmission band adjustment, filter replacement and cleanup. Last photo is with all those things mounted on frame
Very nice! I've rebuilt engines in between their frame rails and know the difficulty of moving over and under to install pistons and such. Keep up the good work!
Reactions: zidodcigalah
Discussion Starter · #14 ·
Thanks guys! Here are some more pictures with engine, trans and transfer case mounted on frame:
4417571
4417572
4417570
I used electrolysis to remove brake dust, grease and rust from brake calipers:
Discussion Starter · #17 ·
Here are some more photos after paint job :) Unfortunately Jeep almost fell off towing trucks, so I'll have to redo the fenders...
4445700
4445701
Engine bay after painting/cleaning :)
4445702
4445703
4445704
1 - 17 of 17 Posts
