Well I started this project a couple of years ago, and as it turns out it is time to get the ole girl up and running. Unfortunately what I documented on disassembly is lacking and what I thought I would remember hasn't worked out for me, :rolleyes:
I purchased a Rebuilt 2.5 long block, have it all cleaned and assembled and dropped back in, but for the life of me can not find all the vacuum line documentation and memory is at a loss, :)
I have been searching for vacuum line drawings or documentation specific to the 95 2.5L but having very little luck.
In the meantime ran across the idea of eliminating the charcoal canister and emissions, not sure if the ECM will allow it.
Does anyone out there have diagrams of the stock vacuum lines routing and or a diagram on how to eliminate the emissions that would work.
dont eliminate the charcoal canister your garage will smell like gas
This should work for you
