Have a 1995 wrangler. Changed o2 sensor and now have clicking under the hood when key is in the on position. will not start. can anyone help.
What was going on that prompted you to change the O2 sensor?
What's making the clicking noise?
Good Luck, L.M.
Clicking under the hood.
First I would like to thank you for your response. I'm new at this. Did a check engine light read. Was a 51 code o2 sensor. After changing the o2 sensor tried to start and now have all 4 relays clicking with no start. Have changed o2 sensor before with no problem. Had no problems prior to changing the o2 sensor besides the check engine light.
First things I would do is check and clean the battery cable connections...both ends, and your ground connections at the block and firewall. Then I would charge the battery fully. You seem to be describing bad battery/starter symptoms that may be unrelated to the O2 sensor replacement
