The air in general whether hot or cold will start to blow but not out of the vents when i get it up to about third gear. Has anyone had this problem and know what needs to be done?
Almost sounds like a vacuum leak, Or the vacuum reserve thing under the battery box might be bad. The black box under the battery tray only has vacuum line hooked to it, The motor doesnt pull as much vacuum at high rpm. Try searching on here for those solutions.
Hey guys,are there any common problems that you know of with the 97 wrangler 4.0 A/C units,my freon is leaking?
