Did a search, did not find much.
What’s the expected cost to have clutch, throw out bearing, rear main seal replaced in the south?
Rear main is leaking, may as well put new clutch in also.
I’m to old to fight removing transmission.
Just a tip. Make sure it is not the valve cover leaking and running down. I made that mistake and had the trans pulled for nothing.
The cover may be tight and still leak. Flashlight and mirror or reach behind with your fingers and get below the cover to check. Good luck.
I had my 5spd Tranny in 4.0 TJ rebuilt as well as clutch and throw out and sealed slave unit and flywheel replaced with my front and rear diff fluid changed and t. Case fluid changed in Texas for $2400 if that helps any.
