What should I be seeing on the low/high manifold pressure gauges for my TJ.
Recently replaced accumulator, performed a Vacuum test everything checks out good.
Depends on outside temp
Standard P*V=n*r*T
http://rechargeac.com/how-to/ac-system-pressure-chart
Thanks for the link!
AC guys chime in here. So based off the link for my enviroment, which is at 90° and high humidity my low is within spec at 45 to 50 psi. My high is at 330, a little high.
My AC during the day struggles to keep the interior cold. At night I have Ice cold ac. Should I be concerned about my AC High pressure being where it is or is it just the intense local heat.
