Are these for offroading cause I know in a manual jeep your supposed to be in those gears? What are they for?
Nothing wrong with asking questions. Well, usually at least.Moabrubi said:You ask a lot of questions.
He has asked a simple questiions that can be easily searched for. There comes a point when you need to search first, If you can't find a specific answer by searching then fine.Nothing wrong with asking questions. Well, usually at least.
Every automatic has that option..... Jeep, truck, car, van.IWANNAOFFROAD said:Are these for offroading cause I know in a manual jeep your supposed to be in those gears? What are they for?
Oh, your right I didn't see that. A little much there op.Moabrubi said:He has asked at least 5 today. There comes a point when you need to search first. If you can't find a specific answer by searching then fine.
x2......chartay said:i'm losing faith in society...
Its so you can select only those gears with a auto. I.E. when engine braking.IWANNAOFFROAD said:Can some one just answer my question
They are to put it in 1st and 2nd gear for what u use it for is for u if u wanna pretend u have a manual go ahead u wanna pretend to be a race car that works to they're used for whatever u wanna use them for!IWANNAOFFROAD said:Can some one just answer my question
ok thank you I looked it up on google before posting this and none of them were jeeps. Also should I use them for off roading purposes or just put it in drive?They are to put it in 1st and 2nd gear for what u use it for is for u if u wanna pretend u have a manual go ahead u wanna pretend to be a race car that works to they're used for whatever u wanna use them for!
.... ahh I just cant believe this... what... ever... u want. Try it out! GeezIWANNAOFFROAD said:ok thank you I looked it up on google before posting this and none of them were jeeps. Also should I use them for off roading purposes or just put it in drive?
As I said. Every auto has that ability. Trucks cars vans doesn't matter. Does the same for all of them....IWANNAOFFROAD said:ok thank you I looked it up on google before posting this and none of them were jeeps. Also should I use them for off roading purposes or just put it in drive?
