I currently have a 4 speed tranny and I want to switch to a 5 speed. Will a 5 speed just bolt right up or is there a major difference ? I really hate the 4 speed as I do alot of freeway driving. Thanks for any tips and help on this mater
a 95 2.5 four speed? Auto?? Letme know, if it is an auto there is a lot of work if it is a stick I would love to know what tranny you have now.
Anyway for the trans swaps to AX-15 which is what you really want you need a bell housing, tranny mounts, input shaft to the T-Case 21 -23 spline and then you may need a new driveshaft for length problems.
So it is not real simple but yeah overdrive on the highway is something you really want.
jeep hasnt used a 4spd trans since like somewhere around 84-85, so if you have a true 4spd in a 95, it isnt a stock item. Does it just have a 4spd shifter handle on it? Have you ever tried to shift into 5th gear?
If it is an actual 4spd, then you will need to swap out the transmission as well as the t-case
A forum community dedicated to Jeep Wrangler owners and enthusiasts. Come join the discussion about reviews, performance, trail riding, gear, suspension, tires, classifieds, troubleshooting, maintenance, for all JL, JT, JK, TJ, YJ, and CJ models!
