Installed a RC 2.5 lift gave me 4 inches of lift from the stock worn springs. when I first drove the jeep it had a bad vibration. made my own T-case out of 1 inch square tubing. got rid of the vibes. I also have a 3 inch body lift. the t-case drop doesn't look good an want to ditch it. Do I need an SYE or just a different drive shaft. it not a huge lift so I don't wan to spend tons of money. I plan on doing ditch the BL an doing SOA on 2.5 inch springs with a V* swap in the near future so this wont last long either.
:rolleyes:
First is to get a magnetic angle finder and determine what you pinion and drive shaft angles are. If you still have the stock shaft with a slip yoke front end then take a look at the pictures and set your angles for a 2 joint shaft.
