Putting the 2.5 inch Teraflex Spring Coil Set and Bilstein Shocks on my 2013 JK 2D with stock rims and 255/80/17 Tires.
From everything Ive read and seen online on these forums is that there should be 0 issues with the set up?
Mechanic calls me today and says the lift is all installed but there is an issue with the new "sway bar" rubbing on the rim/tire and that I have 3 options.
1. Forget?
2. Tire Spacers
3. Use Stock sway bar?
I wasent aware the teraflex 2.5 inch coil spring set even comes with a new swaybar? Why is it rubbing?
1. Forget?
2. Tire Spacers
