So interesting development in my lift install has me a bit stumped.
Set my LCAs as per RK instructions (which I know may need to be adjusted) but when I went for an alignment today my caster came in at 6.5 degrees. The one good thing was that in confirmed my fancy 'measure the pinion with the iPhone level' trick was relatively close.
So I came home tonight and took them back apart with the intent to shorten them up. When I ran out of stroke, I got a bit concerned as my iphone was still showing 0-1 degrees on the pinion. As a last ditch I put the stockers back on and low and behold that put me somewhere between 2 and 3 on the pinion.
A quick test drive did not reveal any problems. Steering was a little sloppier but nowhere near anything I'd call 'flighty' and the wheel returns to center no problem. Tomorrow's commute will help confirm this, but question is:
Is there any reason I should worry about running stock front LCAs on this kit? Is it common for things to work out this way?
I do like the idea of less maintenance on the stock arms, but I was just a bit surprised.
In the same vein I checked the rear end and there appears to be a 6 degree differential between rear shaft and pinion. This seems a kind of high. I do have rear uppers I can put on though to straighten things out.
