Looking to swap my 2.5 for a 4.0. Just trying to see what the basics are for engine swapping. Motor, transmission, transfer case. Harness and Pcm. Anything else?
You will have to move the motor mounts. It’s next to impossible to cut yours off and reuse them. I’d suggest getting a donor set. I swapped of my frame and tub. I had the 4.0 but the frame and body I swapped to was from a 2.5.
