I have searched but haven't had much luck
I'm looking to stretch the front end of my 2 door 2" to 3" inches does anyone have a build thread or real world experience doing this?
I know there are plenty of stretch kits for the rear but I want to do a couple inches up front then 4 or 5 inches out back.
Search more on JK owners. Some have redrilled the frame to move the steering box forward a few inches. You'll have to relocate your coolant overflow tank if you want to move it more than an inch. Are you running coil spring and shocks or a coil over/strut? If you go further than an 1" the coils will bow pretty bad unless you use lower 3" offset spring plates, or you relocate the uppers. Do you'll have to figure out the sway bar too. It would be hard to package but you could move the trac bar to the top of the axle or just move the frame side mount forward. It's pretty simple just a good amount of fab to do.
