Lots of guys run 33s with a 2" BB and a 1"BL . . . should be fine . . . just check your bumpstops or do some fender trimming if you rub a bit.This winter I won't be doing anything off road. Just snowwhat about a BB and 1"BL ?
I've been running 2" and 33's for several months, and wheel it, it's ok. I trimmed the flares since they rubbed offroad, and I don't disconnect all the time. But it can be wheeled, and driven anywhere else, it's just that you've crippled the suspension somewhat. Like someone above mentioned, you can throw on an inch or inch and a half body lift and be perfect for 33's.... Then you're also already set up for the tummy tuck you'll be wanting somewhere down the line....If you NEVER go offroad,and only drive on asphalt,you MIGHT be able to get away with 33s on a 2"BB.Since you have aftermarket wheels,you have a chance.I am partial to my O.E.M. Canyon wheels,and only have an inch or so before my rear tires hit the upper coil spring cups.Not being a fan of wide tires anyway,I plan to run either a 33x9.50 or 10.50x15 tire-I want the height,not so much the width.That is why I don't want 32s,because I haven't been able to find them in narrow width so far.I don't like the idea of wheel spacers,and will never go rock-crawling.Most any terrain around here involves mud and such,and taller,narrower,more aggressive tread seems to work better.Just my 2 cents-take it as you like!
if you install 2" bumpstops front and rear (which i think comes with the Skyjacker BB) you'll be fine. adding a 1" BL will definitely help save your flares.I have soft 8s with 4 inch bs- can I get 33 inch duratracs on with a Skyjacker BB. According to Skyjacker the biggest is a 32 but they don't make duratracs in a 32![]()
You'll be fine dude.25172021k said:I have soft 8s with 4 inch bs- can I get 33 inch duratracs on with a Skyjacker BB. According to Skyjacker the biggest is a 32 but they don't make duratracs in a 32![]()
did the budget boost come with 2" bumpstops front and rear? if yes, then go with the 33s. if no, then go with the 31s.Bump. So I got the BB on and I have 5 -31x10.5x15 and 5 33x12.50x15 sitting my basement- which ones go on?!?!
Go for the 33x12.5s, you'll be fine dude25172021k said:The BB came with bump stop spacers. They are about 1" then the bump stop itself extends about 2" from the cup. Is this enough???
