Would a 2 inch Coil Lift be recommended? Or should i just leave it the way it is?
nah you need to get the sye and cv driveshaft. a t case drop is just a band aidi thought that if you went with a 4 inch lift you ran into more things like a slip yoke eliminator. Is this not true?? Is it just a couple hundred bucks more to get a 4 inch over a 2 inch??
Would a 2 inch Coil Lift be recommended? Or should i just leave it the way it is? View attachment 932
Cabela's off-road adventure 1 and 3 is a good startAnother piece of advice, learn how to drive your rig off-road
