1 - 9 of 9 Posts
I need new tires, I want to do a small lift in the near future. If I buy new tires now and keep the same size, then lift the jeep 2" in a few months.
Will it look wonky?? I would like to see some pics of tjs with a 2" lift and standard size tires.
Can you help me out?? I know you can, this forum has always been extremely helpful.
I did a budget 2" lift on my TJ using my buddies coil springs from his JKU after he put in his full 2 1/2" lift on. It still looks good with my tires, although I'm hoping to be able to upgrade to 33's soon.
Why not do 31" tires now and then when you add the lift you already have the tires done?
Top picture is pre-lift, bottom pic is post-lift. 2" Skyjacker coil spacer lift with stock 30x9.5r15 tires. I personally thought it was going to look pretty doofy but it didn't come out bad at all. Just gave it a little more of an aggressive stance and helped a lot with clearance on the trails.
Pretty sure these were stock, might of been a bit bigger as they rubbed just a little before the lift.
2" BB just before I put on 33's.
Really bad picture my driveway sits at an angle and I'm shooting pic upwards.
It looked far less stupid than this picture shows.
1 - 9 of 9 Posts
