Hey Gang,
Looking at a TJ w/6cyl and manual 5speed....it 'may' need a clutch soon...
Is it any more pricey/hard/PITA than any other manual clutch?
What life span have you all been getting?
Anything I should look out for when I go look at this one?
2000 TJ
102,000mi
basic leaks around the engine block and around the crank pulley and tranny, any visible pulley wobble = inditates worn keyway and shaft and may/will require replacement in shaft (who cares? Think of bad crankshaft or new engine) , in test drive i would try to hear if it makes clinking noises when braking and turning and/or feel if the steering wheel pops or knocks..
as clutch goes it depends on your driving.. you may burn it in a month or it may last few years
Good luck
