Recently, my tj body was separated from the frame and motor. TJ had a ton of rust and the frame needed lots of work. After the repairs, jeep was put back together in a rush and I'm finding that the lines that go to the intake and probably EVAP may have been hooked up incorrectly. Now I'm not well versed mechanically, but I know enough to follow a conversation.
Can anyone explain what each of the ports are coming off of the intake? And what line should be hooked up where? I'll share a pic of how the jeep was returned to me.
From what I read, one of the ports should be capped off, and maybe that should be the one in the front? When I got the jeep back, there's a line hooked up to that port and it maybe going to the cruise control? I have no idea actually, pic below with pretty green circles.
The second port didn't have anything hooked up and was whistling so I put a cap on it, which made the jeep run better, but I dont think thats right. I think the vacuum line thats coming out of the firewall should go there but im not sure, and its currently hooked up to maybe the evap pump? Again, no idea.
The third port closest to the firewall was simply capped. I dont think thats right either. But I dont know what could plug in there.
Any advice is appreciated. I've been to two shops already that gave me the run around.
