1 - 13 of 13 Posts
I thought that ALL 2000 Wrangler Sports had the cruise control on the steering wheel.
Take a look at the picture.
I do not see the control there.
What years DID come with the cruise control?
Maybe they changed out the steering wheel. :rolleyes:
You can add it. There are some kits out there on ebay $$$ using factory parts or you can piece it together yourself. It depends if you have some of the wiring and vacuum lines already installed from the factory.
I have cc on my 2002 sport. But it's a manual so it's kind of useless. I have 33's and havent regeared from 3.73's so every time im going uphill I have to downshift and reset cc then upshift and reset it again. It disables every time the clutch is engaged
I never drove a standard vehicle with CC, sounds like its a pain in the rear end... BTW I have standard in my jeep as well, same gearing 3.73 but with 31's only.
cruise control did not become standard on any TJ until 2002 when it became standard on the sahara.....I think all saharas from 2002-2004 had cruise control....and also the one-year-only 2005 limited edition LJ rubicon-sahara got cruise control. I have cc on my 5-speed sahara and have yet to use it other than to see if it works.
CC worked fine on my 01 sport (manual) when I was runniung 30's. After lifting and putting 33's on with .410 regearing it almost came back to normal but not quite. .456's installed and its useful again. Note to self and anyone else, 4.0 , 5 spd, on 33's = .456 gears. I made the mistake and tried the .410's. A thousand dollars later all is well. What are almost brand new G2 .410's worth :)
Discussion Starter · #13 ·
Well, I test drove the 2000 Sport yesterday.
If I decide to get it, I guess MY cruise control will have to be my right foot, because this jeep just doesn't have one.
1 - 13 of 13 Posts
