Will a stock transfer case shift linkage work with a 1pm bl mine is not functioning right not sure if it's just old or bl threw it off
Show Me Your 8008135!
It will work...if you have a motor mount lift, it may be all outta whack. You can probably adjust it. If you don't have a motor mount lift, you may need a drop bracket to install on it for it to work properly.
If you have the money...search for Novak cable shifter, buy one (about $200 after shipping), install it, and never dick with it again. The Novak cable shifter is amazing.
