I've done a lot of searching and read a lot of old posts... and this helped me understand what I'm working with, what is recommended, and the basic process for getting this done. But I still want to run the pieces that I have picked out by yall. (don't worry I'm not here to talk about gain vs. volume or 2ohm vs 4ohm
I have a 2001 TJ with the built-in sub (which I have taken out of the center console). I have the factory soundbar. I have an aftermarket HU:
Pioneer DEH-1300MP
Why do they list CEA2006 specs at 14w RMS but Continuous Power Output @ 22w RMS? Which one does this HU have?
I am planning on purchasing:
Should I get a new HU to support these speakers?
With or without a new HU, do I need an amp? If so which one is recommended? That is one thing I could not determine based on previous posts.
Thanks in advance!
Pioneer DEH-1300MP
- CEA2006 Specs: 14 watts RMS x 4 channels (at 4 ohms, 20Hz-20kHz, 1% THD-N)
- Continuous Power Output: 22 watts RMS x 4 channels (at 4 ohms, 50Hz-15kHz, 5% THD)
- Maximum Power Output: 50 watts x 4 channels
- Select Increments Dash-Pods
- Polk Audio DB 522 for the fronts
- Polk Audio DB 652 for the soundbar
Thanks in advance!
