Maybe someone can shed some light on my problem, I want to change my windshield hinges but I was told some of the nuts are not attached so you have to fiddle through dash to get at them, Any suggestions
Thanks hpclayto like you said, piece of cake couple , of fender nuts had to replace but the cowl was extremely clean and drain hole was clear, So far I got 4 torx bolts loose on one hinge, I am using a little benzomatic to heat the bolts 2 - 3 times then they will come out, anti seize them put them back in snug and will continue till all are out and cleaned, then order a new set of hinges-thks Rich
