Hi guys, I have been searching and reading, and I didn't find an answer to my current situation, and need help.
I have a 2002 Wrangler Sport 4.0 with a manual transmission (NV3550). A new clutch installed in 2011 (i bought her in 2012). She was running fine, until last month, I couldn't get her into gear, so I drained the transmission fluid, filled her up with Royal Purple Syncomesh and she improved considerably. However after that she started making noise when I pushed the clutch pedal down, three weeks later, not I can not shift into gear while the engine is running.
With the engine off, she slips into every gear (and reverse), both with the clutch down and without.
If I start the Jeep with it in first gear, or reverse engaged, she moves. When I try to hold her back from moving by applying the brake, the clutch makes a loud noise.
It feels like what ever is supposed to separate the clutch and the flywheel, isn't pushing them apart.
I replaced the master and slave cylinder last night (bench bled the whole unit), and it still won't shift into gear while running.
Any help is appreciated.
-Jim
-Jim
