i have a 2003 jeep wrangler 4.0 4x4 5 speed manual with 198k on it been drivin it all summer. Today im driving around and feel lil vibration thought nothing of it really has a small 2 inch lift so there is always a little something its a jeep but then it got a lil worse was driving slow every time i hit a bump i heard clunk clunk. So thought maybe wheel spacer came loose as they do but it wasnt everything was tight the drivers side rear has a fair amount of in and out play no up and down but that is 100% the noise i jacked up other side and that side actually moves more I know some is normal but it has never made noise before and both rear drums always wore weird/not even since i got it.. What can cause in and out play? i will upload a vid soon so you can see how much it moves.
Possibly wheel bearings.
Welp bois it appears that the carrier bearings are shot the whole thing has up and down play when i press on it with pry bar. The pinion is fine tho am shocked cause its a jeep. How hard is it to replace bearings ? or should i just go find a used decent rear?
