2003 wrangler death wobble
1188 Views 4 Replies 4 Participants Last post by  Shark_13
Hello guys I have a 2003 wrangler and it has the death wobble I don’t really know where to start considering everything at a glance looks fine mechanically if you have any tips on how to diagnose can you please tell me thanks!
Welcome to the Forum 1993_MAZDA_MIATA,
Have your tires "Force Balanced" to start. Not every tire shop is capable to do this, nor does every tire shop even know what force balancing is.
If the DW continues, have the suspension examined by a competent alignment shop.
Other posters may have additional suggestions.
Good Luck, L.M.
Good Luck, L.M.
Thanks bro I’m not sure I will definitely look into it thanks
If the balancing doesn't work, check your alignment. Make sure that your Jeep's suspension is in good shape (bushings, wheel bearings, etc..) and if it's lifted, find out what has been done to it (forum can help with that)
Awesome Miata!
Get a helper, do a dry steer test. (There are videos on youtube that explain what to look for)
Sent from my SM-G960U using Tapatalk
